Which grease it best for my new prop
mtbeatle
I am going to be fitting a new prop shortly to my 15hp Yamaha engine.
Can you recommend a grease for the shaft?
Is there any I should avoid
Thanks
Craig
Re: Which grease it best for my new prop
Ayuh,.... See below,...
V
V
V
V
V
V
V
V
V
V
V
V
steelespike
As someone here once said any grease is better than no grease.Lbriplate 105 would work.
If I was doing it I would use any lube including ep 90 and check it anually.
catfishr1
Yup for sure. Bond-o's byline. I like &use the outboard multi purposelube. Or anti seize lube.
Outsider
I'd use one that gets removed and replaced every fall ... ;)
Texasmark
Lubriplate makes a white GP grease that works fine in water environments (most auto parts stores). Otherwise any GL-2 grease wiped on the prop shaft.
Mark
Peter16
quicksilver 2-4-c grease
etracer68
Ensign
Any marine grease, or I use gray anti-seize. All DIY will have it somewhere in there garage. And yes, your prop should be taken off, and clean splines, inspected, and re-lubed every season.
