Re: which is better suzuki or yamaha
I would have to wonder why was a 2001 Yamaha 4-Stroke needed to be rebuilt. I have a 2002, seasonal tuna trips, alot of Catalina trips, local you name it and I only have 400hrs. These things are scheduled to last around +/- 4,000 hours depending on care, but even at 3,000 hours, I don't think I will ever hit (maybe if I retire and fish every day). Was this used comercially, or possibly abused? (I have overheated mine twice, not bad enough to register, thought I had low compression, but just my imiganation still nothing wrong) If someone was able to run it for 3,000-4,000 hours, then I would suspect that you will have problems in other areas if they are not rebulit also. If abused, I would expect the same.
You may also want to ask their definition of a rebuild...ie just torn apart and looked at, just replaced rings, honed cylinders and changed all parts etc, I believe there is diff levels of a rebuild.
