Which is better
Adam76
Hi everyone, new member and new boater here. My question is I have a 21' Cuddy cabin with a 350 5.7 Mercruiser, that came with two props. One is aluminum with a 19pitch and the other is stainless with a 17 pitch, which is better and what differences would there be between them. Thanks
steelespike
Re: Which is better
Generally a ss prop will out perform an al prop.
Give them both a test run paying close attention to hole shot and wot rpm and speed.
tests should be done with a light load.
Adam76
Re: Which is better
Ok thanks, I'm new to boating so I'll see if I can figure it out. what is the optimum rpms that I'm looking for?
craze1cars
Re: Which is better
Depends on the year/make/model of your engine.
Unless it has been removed and lost, you will find a sticker in your engine compartment that specifically provides you this spec/range. Probably says something like "4,200 to 4,600". I usually suggest targeting the higher end of that range....whatever the range for your motor is.
Adam76
Re: Which is better
Well I had it out yesterday with the Aluminum 19p prop, and it ran around 4,200 at around 36mph, what difference would I see by switching to the SS 17p, sorry newbie here. Optimal rpm's are 4,200-4,600. Thanks
Re: Which is better
my guess is one prop was for cruising (19p), the other for water sports (17p). that is what I did with many of my boats.
Adam76
Re: Which is better
Thanks, so then the 17p would get me on plane faster correct?
Re: Which is better
yes, watch the RPM's so you dont over-rev
Texasmark
Re: Which is better
You may be pleasantly surprised with the SS prop. Most SS props come cupped which could add the equivalent of 2" of pitch especially with the thinner blades that most SS props have because the SS is stronger and a thicker blade is not necessary and adds to the already significant cost of SS. If the SS is ported (1 hole under each blade on the barrel of the prop near the front of the blade, then the hole shot will be even batter. The 17p regardless will give you a better hole than the 19 even if they were identical props otherwise. So the SS may up your rpm's to a better position on the "desired rpm" scale, and you may keep your 36 mph and have your hole shot too......whadda deal.
Mark
