hz
- Joined
- Jul 24, 2007
- 62
I have a 1983 seaswirl with a chevy 3.8l 229cid V6 engine. There is a crack in the top of the block where the oil and water ports come through. It only affects one water port and there are small cracks on the outside of the block that allows the water to go into the valley to the cam. This allows the water to get into the oil. This is not on a pressureised water system. Is it ok to use regular J-B Weld or should I get J-B Weld Marine Weld which I haven't been able to find anywhere.
Harris
Harris
