Re: Which jet is idle and which is high speed on the carb?
"So you don't think that the open hole in the upper part of my photo is (missing) a core plug?"
Hmmm....open hole in upper part of photo....you mean at the 11:00 position to the needle seat?
Nope. In just thinking on the carb theory, and the way they manufacture the castings....the core plugs are used to seal holes that they needed to make "on the other side of" the core plug.
They had to drill thru, or make some manufacturing detail, and then they sealed it with a core plug.
So, behind the core plugs, there is generally a very small passageway that needs to be absolutely clean. Small holes leading to the venturi....things like that.
All core plugs that I have seen are on the outside of the carb. I have not examined your particular model carb, but I have looked very very carefully at the 1980 V4 crossflow carbs. I think you have a blockage in the idle tube (offcenter tube) and it's following fuel path. You gotta study it, and see where that fuel flows from up from that tube. It will go into the carb body top...and then on to the side of the venturi...micro holes.....right at the throttle butterfly.
I had a V6 looper that wasn't running right at idle. Crappy. But I just did the carbs, and cleaned the idle side very very thoroughly.
Ran it....ran OK...but then detiorated. Soon wasn't idling right at all.
Absolutely guaranteed that it wasn't the carbs. After all, i just did them. So I thought.
Tore them off, and crap. All of the carbs were blocked in the idle circuit by ???? to this day I don't know what it was. It was grainy, almost like very, very fine sand. It was NOT sand; I have two filters on incoming fuel lines....water separator....etc.
I seriously regret this...I failed to taste the grainy crap. I would bet to this day that is was salt. On these carbs, there is an air path that could take in salt water, and after evaporation, leave the tube tops full of salt. Just a theory. Yours can't do that, I don't think. But....
Clean that idle tube, blow thru it with your mouth, suck thru it with your mouth....you can tell more about how much it is flowing by sucking on it....you can feel the air on your tongue....I tell you true.....
Tastes bad, but you will live.
