Which lube do you use for Lubricating shift cables
Drcoffee
Is there a special oil to use, or just generic silicon, wd40, or something else?
flashback
I generally use what I have handy if it's oil. WD 40 is not a lube so you don't want it.
Drcoffee
Im just concerned that a generic lube might cause the cable sleeve to swell and really make it fail fast
saaristo
I used motor oil. I removed the cables from remote, slided a 2ft rubber hose over the brass fitting and wrapped it around the cable tightly with zip ties. Then filled the hose with oil and attached compressor with zip ties on the other. Air pressure pushed the oil through cables. Like new...or better.
dingbat
Interesting… didn’t know lubing cables was a thing. I just assumed all control cables were sealed for life.
flashback
I have done something similar on motorcycle cables but the last lower cable I put on was Teflon coated and the sheath as well.
Ayuh,..... Ditto,..... I lube the linkages, not the cables,.....
Problem with shift cables is the sheath wears from the cable moving.
Cables only last about 15-20 years
