nightstalker
- Joined
- Dec 10, 2003
- 570
One mechanic at the marina told me to change the water pump in my 1994, 225 Johnny every three years regardless of use. The other mechanic at the marina told me to keep an eye on the pee hole and if it sprays water out stong that the impeller is OK and doesn't need to be changed. He said you can go many years with the same impeller as long as the pee hole indicates that the water is pumping fine. I change the impeller every two years because I put about 100 hours a season on my motor and will continue to do so (small price to pay for piece of mind), but can this guy be right about only relying on the pee hole pressure to determine the condition of the impeller?<br />Stalker
