Which mercruiser manual numbers? S/N inside
Hondo65
OK here is the info I took off of the tags.
Drive Unit S/N 0B643994
Transom Assembly S/N 0B54582
Engine S/N B625638
Does anyone know if these are available online ?
Also I just quickly looked but did not get a number yet. It has an Edlebrock Carb would this be standard on a Sea Ray (1987) or is this aftermarket?
Thanks in Advance
Hondo
Hondo65
Re: Which mercruiser manual numbers? S/N inside
Thank you sir. I'll try and find #9 on Ebay
Hondo
Hondo65
Don S.,
I followed your link but unfortunately I was only able to get the first 7 pages of Manual #6. Any Ideas how I can get the rest? Thanks for helping this cadet.
I used to think I was pretty smart but now I feel lower than whale doo doo on the bottom of the ocean
Hondo
Hondo65
I also have the same problem some others here have with the trim switch not working in the up direction. The trailer switch works but not the Up. I am so new to this I need to see pictures and diagrams just to figure out what part is what...
Don S
Move your cursor over the letters of the sections you want to open. The links aren't visible, watch your cursor change.
Hondo65
Thanks Don, I had just figured that out right after I asked. I remembered something in another post about that. I try to do searches first but sometimes it helps to cheat and just ask
Thanks again
Hondo
