weekendfisher
- Joined
- Feb 26, 2010
- 79
Hey Guys
I have a Johnson 50Hp with the small gear case my prop is pretty banged up so i want to replace it.
The markings on it are 11-3/4-17 what I want to know is the 11-3/4 a sige number to indicate the diameter or is that two separate numbers with different numbers ?
The reason i as is that it has been very difficult to find that size in Aus and Iboats aren't shipping outside of USA or Canada at the moment and i am in a bit of a rush to replace the prop.
As it is damaged i am not willing to run it to WOT toget all of the figures so i need to replace it with something the same or very similar.
So far i have the option of 12 1/4*15 which i believe is a smaller pitch which would lower my top end speed
13 1/4*17 so larger diameter but same pitch as original ???
That is what is locally available without having to order one in... Will either of those suit or should i try chasing some outboard wreckers as i need it for the weekend.
Thanks
Thanks
