SleekCraft85
- Joined
- Jun 29, 2012
- 28
My boat is a 21" SleekCraft Diplomat powered by a 260hp volvo penta (optimal rpm range i believe is 4000-4400 as per manual) i normally go out with 4-6 ppl on board and i tend to cruise at around 2200 rpm. i would like a well balanced prop without sacrificing fuel economy, hole shot, or top speed).
At the moment i have the following 2 props:
OEM "elephant ear" 15 X 19 prop (max rpm 4000-4200 max speed 42-45)
Michigan 14 3/8 x 23 prop (max rpm 3800ish max speed havent clocked it on gps but i assume is in the upper 30s)
and i am considering purchasing the following 4 blade (14 1/4 x 19)
Solas Amita Aluminum Boat Propeller #8814-143-19 for Volvo Penta Sterndrive Aquamatic 275 Long Hub 110 - 260 HP - iboats
of the 2 i currently have which is better for what? is the 3800 max rpm on the 2nd prop putting too much load on engine?
and would my current setup benefit from the 4 blade? (if so, know of any discount codes i could use for check out? lol)
thanks
thanks
