otterbfishin
- Joined
- Dec 6, 2004
- 31
I need an outboard jet to run the 16' plywood riverboat I am building which will weigh about 300 lbs. My average total running weight for the boat and occupants would be 900+ lbs minus the motor. <br /> The boat at 900 lb capacity is said to plane out great with a 35 or 40 HP motor with prop, but I can't run a prop in the shallow glacial rivers here in Alaska. One builder said that he runs a 40 HP Honda 4-stroke with prop, so the transom will float it's 190 lbs. fine.<br /> I believe a 50 or 55 HP with a jet would do the trick, as I am told that you loose about 30% of your head power with the jet lower unit. This is a guess.
<br /> I need help choosing a motor. I want the lightest, most reliable motor I can get. Which is it? Is there a website that compares outboard motor specs that I can review?<br />Thanks,<br />otter
