which ports to use on water/fuel separator
aggiedave98
I have a quicksilver standard water/fuel separator like:<br /><br /> http://www.sterndrive.info/sterndriveparts/id1.html <br /><br />it has 2 inputs and 2 outputs. 1 set of inputs/outputs on each side.<br /><br />my manual says that there is an order you have to use... like the input on on side to the output on the other side.<br /><br />i have had it hooked up both on one side almost a year now (I put it on last year). What will that do? Because of where it's mounted I can't really hook it up the way the manual says. What do I do?<br /><br />Thanks.
bigbrownbuku
Re: which ports to use on water/fuel separator
you will be fine aggie. the manual is probably referring to increased fuel vaccum by not choosing the straightest path. reading your other post about the full water/sep filter, you can get a replacement racor element with a spin on clear bowl the will fit your current filter head. with the amount of water you had in your tank it would be money well spent.
Don S
DO NOT get a clear bowl for an IO or inboard set up. The clear bowls are for outboards.<br /><br /> Racor Filters
bigbrownbuku
ya gotta love the us coastguard.....<br />use the filter that meets the standards
