northface owner
- Joined
- Jul 2, 2005
- 4
Hello everyone! I have been having trouble with speed/rpm's on my pontoon, and hope you experts can help me.<br /><br />I have a 1989 Misty Harbor pontoon boat (the one with large square pontoons with inverted V on bottom), it is a fairly heavy boat and I dont know how much it weighs, or even if that is important.<br /><br />I have a 1973 Johnson 135 HP motor that we bought seperately and installed on this boat. Since the motor already had a prop on it we went ahead and used it. The prop is a 13 X 19, and not in the best shape. I did remove it and sharpen the edges, which seamed to help some. It does have a dime-size chunk missing from one blade. <br /><br />The engine tag says it should run between 5000-5500 RPM at WOT, but the tach on the dash is only showing 4200 RPM's. We can lumber around the lake at a whopping 18 MPH, and thats not good enough. We used to have a 135 Evinrude on this boat, and I could ski behind it, now we can barely go tubing. When I make a turn the boat slows down tremendously, which is to say it DRINKS fuel. Also, at times when I make a turn it seams as though the prop stops spinning altogether, and when I let up on the throttle it will take off again.<br /><br />I need this boat to do these things:<br />a) go faster<br />b) be more efficient<br /><br />Can anyone help?<br /><br />Thanks in advance!!!!!
