Which prop to buy?
miichael18
My current prop is factory aluminium not sure what size/pitch but my question is can someone figure up what prop i need if i take mine off and get the pitch? In my manual it says wot is 5000 rpm right now my boat does 29mph @ 5600 rpm. So i need a different pitch I'm assuming? I do not have tilt/trim and its a 1974 evinrude 70hp on a 16ft dixie tri-hull. I guess since it tachs more than it should i need a bigger pitch prop?
Any info would be great.
miichael18
Re: Which prop to buy?
im not changing it to upgrade im changing it because mine is wore and pitted bad.
AlanR
Read what prop you got on it now. it should be stamped right on the prop its self. Id say maybe a 15 or 16 inch would be correct but check what you got.
miichael18
The props ive looked at dont have 16 though. so should i get 15 or 17? i want most speed i can get. right now it runs 29mph @ 5600rpm with 14 x 16. does a bigger pitch mean geared higher? like a 17 would be faster with lower rpm? or what?
Props on here pitch are 10, 11, 12, 13, 15,17, 19, 21, 23
xtraham
13 1/4" X 17" would be my starting point...
JB
Go with a 17, Michael. That will bring your WOT rpm down to closer to 5,000 and it will probably add a bit to top speed.
AlanR
Yeh i wouldnt go any more than 19 on a 70
miichael18
will that make it faster with lower rpm? or will a 19 make it slower with lower rpm
xtraham
that 70hp does not like a 19p prop. I have a simular set up except v haul and have tested several props, @ diff. engine hights and trim my very best is with the a/v plate 1" above the haul and 13 3/4" X 17" mich. aluminum prop. jumps out of the hole and 32mph @ 5200 rpm's your haul is a little harder to push, if you want to try a 19 try to find an old oem aluminum 13"X19" they had no cup
AlanR
Yeh like xtraham You prob get the best preformance with a 17 inch aluminum prop
miichael18
so get a 14x17 and it will make it have a lower rpm and a higher mph tyhan my 14x16?
mrtool2u
Where are you located at,,I have a 17 pitch that you could try,,I am located in Western Pa.
cougar1985
have a buddy that owns a prop shop and for every 19p he would sell for a 70 he would sell 10 17p,s. a trihull takes more to push so id say 17 max for best all around performance.
AlanR
So, we all agree 17 is the way to go.
