Which prop?
tipitina
My friend just broke the prop on his 40 hp Johnson. I believe it is an '84 or '86 model. The motor is on a 16' aluminum flat bottom boat with drivers console. He hit a stump and broke one of the blades on the prop. What advice for selecting the right pitch prop for this boat? It is used strictly for fishing. Thanks.
CATransplant
Re: Which prop?
Are there any markings on the broken prop? If it was working OK for him, then a prop with the same pitch would be what to replace it with.<br /><br />Most props are marked somewhere. If it's the original OMC prop, there should be a part number. If not, take the old one with you to the marine shop or OMC dealer. They'll have some good ideas for you.
