Which Prop
cobraphil69
Hi new here had jetski s in the past and just bought my first boat a 1985 sealine 22 fitted with a volvo penta 5.0 200 hp v8 .the prop is damaged and was wondering what size it should be and what the leg is, there is a lot of models and its -5 outside and dont fancy going in for a look thanks in advance
steelespike
Re: Which Prop
Welcome,
usually the size appears under the prop nut. The actual prop size could depend on any number of things on a 25 year old boat. the health of the motor,what kind of weight typically carried,boating activities,etc. You can probably get the prop repaired and when the water isn't hard make a few test runs and get the prop size,max rpm and speed lightly loaded to us.
If you read the stickies at the top of the page and the helps on the prop store page it will help you understand props better.We'll be glad to help with any questions and help with a selection.
