Which prop?
armjr
My boat is an Xpress 1756 with a tunnel. I am primarily a freshwater fisherman but I do enjoy fishing the shallow bays. I pulled the boys skiing years ago but likely never will again with this boat. I'll likely get the prop that I have fixed and also buy a new one to either use or as a spare.
In the most extreme conditions (which are when I will be in the most danger of getting to camp on a mud flat in the middle of duck season or searing Texas sun) I need to be able to get up and moving in 2 feet of water (and mud) or less. I usually accomplish this by cutting the motor to one side, hitting the gas and going in a tight circle until I get some water moving in the tunnel and then I can go.
What would be your suggestions be as to the pitch of the new prop and a four blade as opposed to a three blade (like I have now)?
Thanks in advance.
Alan
Don't have clue with your situation, my only comment will be since speed is what your trying to achieve, then lower the pitch to get better hole shot. You can over rev at WOT but you will come up quicker
