Which sensors has a Suzuki DT40?
BoatAddicti0n
I need to know which sensors a Suzuki DT40 1990 has
Meaning which sensors could disable the engine at WOT.
(I suspect this is the problem I have)
Happens that the my Suzi starts and runs perfectly until it reduces RPM at WOT.
It recovers the RPM/speed if I release the throttle and push it to open again.
I have ruled out fuel restriction, air in fuel system, and oil filter. Spark plugs are new.
Water pump pees steady with pressure. The engine does not seem hot.
Original thread: Suzuki DT40 fails at high RPM
(decide to post a new one since it could be an important question to many of us)
- APPRECIATE any input!
deejaycee_2000
Re: Which sensors has a Suzuki DT40?
Go to brownspoint.com, download the part list pdf for you motor then you can see where all the sensors are .....
