Re: Which size Oil Drain Kit do I need? 1997 MerCruiser 5.7 Alpha One
Is installing this drain kit fairly easy? Other than the obvious trying to get under the motor. Are you simply replacing the drain plug on the oil pan with a hose?
It's as easy as removing the drain plug.
Mercruiser indicates that it makes the oil easy to change because you can fish the hose out through your drain plug and then let the oil drain via gravity.
The hose I bought from Overtons was too big and wouldn't go through the hole.
I clamped the other end of my drain hose to the port riser.
This way I can hook up my
Moeller vac pump and suck it up through the hose. It actually is easier that way since you can pump the handle about 15 times and change the filter while the oil is being sucked up through the hose. It only takes 5 min or so hot or cold. Since the hose is larger diameter than the tube you would stuff down through the dipstick-tube, it sucks the oil through it much faster.....
It's also a LOT faster than letting it drain via gravity.....AND you also don't have to stand on your head trying to fish the oily hose through the transom drain!
This is the one I got from Overtons.
It was around $30+ shipping. You have to specify the correct thread pitch/size. I did and they sent me the wrong one so they sent me another one free of charge. (now I have a spare.......wrong size though!!
Regards,
Rick
