Re: which size wire?
I have a warning about that table - it only considers the voltage drop (as a percentage of the total voltage).<br /><br />Try asking it what you need to move 100 amps 1 foot with a 10% drop. It says you can do 100 amps with 18 AWG wire!!! (Oh my, pretty smoke)<br /><br />I would not move 40 amps with 10 guage.<br /><br />Try this for a standard. When looking for the max current through a wire I like to use the standards used on land. 14GA can carry 15 amps, 12GA can carry 20 amps, 10GA can carry 30 amps, etc.<br /><br />On the Anchor site under technical data it says you can carry more, but that is for 105 degree Centigrade wiring. I would rather not have the wires run that hot.<br /><br />Way to calculate this is remember 14AWG=15amps, and 12AWG=20amps. Then for every 4 guage size changes you double or half the current.<br /><br />For example, it you want to know what 6AWG can carry, take 14AWG=15A, then 10AWG=30A, and 6AWG=60A.<br /><br />If you need 40A, try starting at 12AWG(20A), go 4 sizes to 8AWG(40A) and you have it.<br /><br />Also, I have not checked their sites math yet. Does anyone know if the length is one way or round trip? If you have a 15 foot run you need to consider the current needs to go out and back, or 30 feet.
