Re: Which spark plugs are the right ones? '58 18hp
I have the almost identical dilemma. I have a '58 Evinrude 18hp 15024.
Original Parts Manual specifies Champion J6J.
New substitute for J6J is J6C according to Champion site.
Champion Application Guide indicates J8C.
Other posts on this site and others specify J4C. My motor currently has J4Cs installed, but they are a bit black.
A rule of thumb for 50 year old and older Johnson and Evinrudes is to use the J6C plugs in outboards without a thermostat, J8C plugs in cold water conditions or extended low speed operations.
In thermostat equipped motors, J4C plugs are recommended. J6C works great if fouling problems occur.
The newer factory charts are not accurate for those motors over 50 years. If the decals on your motors are still readable, go by those recommendations.
Plug numbers changed over the years - J6 and J6J plugs are now J6C - same with the J4J and J8J numbering.
