Re: which tach for thunderbolt ignition?
Chris, you have two choices. You may use a standard aftermarket universal outboard tachometer, and slightly alter the engine wiring or you you can try to locate a proprietary merc tacho from the early 70s and use it without modifing the wiring.
I recommend the former plan. To alter the wiring on the motor, move the brown wire from the starboard side of the switchbox to either of the yellow wires on the rectifier. Now hook up any aftermarket tach, using the directions for your merc and set the selector switch on the tach to 12P.
