I have a 97 four winns 180 horizon rx with 4.3gl/sx.
I have only had the boat in the water 3 times since I bought it 3wks ago.
the first time was a water test performed by the previous owner.
The first time I took it out as the new owner, I had a bad over heating issue from idle on to 45+mph it ran from 200-220, I stopped and brought it back home pulled the thermostat out it turns out it was rusted closed. On muffs it ran at 160 for about 25min at about 800rpm which satisfied me enough.
Second outing I had it warming up at the dock while I loaded the wife and kids (about 10-15min) the temp was almost at 220, I put it in drive and it dropped to 170 and sat there as long as I was moving I drove it at about 40mph for about 1hr and it sat at 170 I slowed down coming back into the harbour and cruised just under 10km/h according to the GPS, and the temp stayed steady until I stopped and waited my turn to exit the launch idled and she climbed back up over 200.
I decided to pull off the sea pump, good choice on my part 1 of the screws was hand tight I am guessing it was sucking air, the gasket showed evidence of a water leak. the sea pump is (Johnson style- the one with the 3 screw on the back cover) any way I pulled the impeller out and 6 of the fins stayed bent over so I am about to put the new one in but I am thinking someone may have put the old one in the wrong way, the reason I think this is because the fins are bent right over and when it the shaft rotates it looks more like it would push water out the inlet and want to draw water in the outlet. I have a manual but it only shows a pic of the crank driven pump. Does anyone have a picture a Johnson style pump with the impeller properly installed?
Sorry for the long explanation I just wanted to give a lot of background
