Repowered a 2003 2359 from 5.0L to 5.7 MPI last year. Changed the Merc upper from 1.62 to 1.47 SEI. I kept the original lower. I expected whine during break in that disappeared around 20hours. Boat ran great for 60 hours. When coming in from last tuna trip the outdrive started sounding different. It was a high pitched whine which my dad thinks sounds like grinding. I changed the gear oil hoping it was low. The gear oil was really dark and had a lot of metal flakes. I took the boat back out for a 20 minute run to see if anything changed, which it did not. Came home and drained the gear oil, the magnetic drain screw had already grown a significant metal shavings beard. I pulled the upper and the lower. I checked the engine alignment, u-joint and gimbal bearing which all looked great. I turned the u-joint by hand and it seems the upper gears make more noise than I would expect but not sure what is normal. The lower unit gears are hard to turn by hand by are smooth. I cannot visually identify the source of the metal flakes which I assume is causing the noise. Any suggestions? I took a video of the boat running for the noise demo and of turning the upper and lower units by hand.
engine running(last 1/3rd is the best as the engine drowns out the noise in the beginning)
IMG 1752 - YouTube
upper
IMG 1756 - YouTube
lower
IMG 1757 - YouTube
IMG 1752 - YouTube
upper
IMG 1756 - YouTube
lower
IMG 1757 - YouTube
