" white rust" on galvanised trailer,
jurgenscraft
How can " white rust" corrosion be removed sucsessfully from parts of my galvanised trailer, I recently removed the felt lining fron the hull guides on my trailer ond found this corrosion under the felt, I have been told that diesel fuel will remove this corrosion that has formed along the guides, at first I thought that it was sea salt but it is not the case, other than using a wire brush to clean this White rust, is there anything else that i can try, some solvent of sorts., has any body tried diesel fuel?kind regards William Wright,
Bob_VT
Re:
Re:
Alot of hand work. You can use scouring pads but, the reason is it is covered metal. Diesel may work (probably most any oil based product will help.
tashasdaddy
Re:
Re:
googled 'white rust' lots of info, to much to mention.
JB
Re:
Re:
Duplicate posts are not desirable.
See Trailer Forum.
