With a descaled motor all water passages are way cleaner than before and motor peeing strong. The white/blue smoke seen above the waterline appears when at neutral, idle ? aside the smoke, does the motor runs strong thru the whole throttle range ? The motor being an oiling injection model and now running constant 50:1 fuel/oil mix at lower rpm will account for seeing more smoke around that area. Why is the motor running with morefuel/oil ratio than 50:1 ? More oil, more smoke at reduced rpm.
Happy Boating
The white smoke is barely apparent at idle, but is abundant at any bit of throttle. And no it doesnāt run through the throttle range. About 2 outings ago, it would try to die in reverse unless I could get it past the lower part of the throttle range. And it would die at idle occasionally, otherwise it ran fine in the upper range. But the last time I took it out, was when I started noticing the white smoke and quite a bit of it. At the time I attributing to the oil injection lines draining into the crankcase (not recognizing the difference between white and blue smoke at the time) and the extra oil just burning off. But it continued to smoke and steam a little for the rest of that trip. But I could still get it up to full throttle, I just didnāt much and made it a short trip. I took it home and put it in a trash can and it idled very rough and when I would put it in gear and give it a little throttle it would die. Note: it wouldnāt produce a lot of white smoke at idle, but when I put it in gear it would. And then after it would die I would not be able to get it to even idle for at least 24 hrs.
I took it to a mechanic for a diagnostic. He was not supposed to do any repairs but cleaned and put kits in the carbs ( that I had told him I cleaned myself and kitted about 6 months prior, and I feel confident I know what Iām doing). He said it was a fuel delivery issue and also replaced the fuel pump (unauthorized
). The mechanic and I parted ways and the motor runs exactly as it did before. So, very clean carbs, and a new fuel pump.
I also replaced all the fuel lines etc. last year. I am neurotic about fuel quality (no alcohol, I even clear the hose at the pump before filling gas cans etc., and I double check for water in the fuel tank. I did not observe any. I am running 50:1, and the amount of blue smoke, in my opinion is appropriate for premix, especially for as rough as it idles. New plugs also, with the gaps checked. Sorry for the novel, but maybe the devil is in the details?
