Re: white smoke
You may be getting water into one of the cylinders. Pull the plugs and see if one or more look like "New". Real clean! If so, run a compression test on all cylinders and let us know. You may have a bad head gasket...<br /><br />EDIT: Didn't see you had 2 posts going, but I still stick with the advice I gave you. Try to stick with one post and you will get better results for your problem...
