Who has motors and who has engines???
SandMan*
Re: Who has motors and who has engines???
Motor
1. a comparatively small and powerful engine, esp. an internal-combustion engine in an automobile, motorboat, or the like.
2. any self-powered vehicle.
3. a person or thing that imparts motion, esp. a contrivance, as a steam engine, that receives and modifies energy from some natural source in order to utilize it in driving machinery.
Engine
1. a machine for converting thermal energy into mechanical energy or power to produce force and motion.
Different words, basically same meaning...
Some say an engine is just the powerhead, and the motor is the complete unit... who knows
Frank Acampora
Technically, anything that burns a fuel to make power is an engine Thus: Gasoline Engines, Steam Engines, Diesel Engines.
A motor does not burn fuel. Thus: Electric Motor, Hydraulic Motor.
It is possible to have hybrids: Diesel electric locomotive or tugboat where a diesel engine runs a generator to supply power to an electric motor. The advantage to this set-up is that the engine can be run at its best rpm for power and torque and the electric motor can be designed to deliver maximum power or torque at stall or 0 rpm. Thus a locomotive which must start long lines of freight cars moving has maximum power right at the start. Once moving, the motor can be electrically switched from shunt wound to series wound which gives better speed control and higher top speed.
Old Cub Cadet lawn tractors were gasoline engines driving a hydraulic pump which in turn drove a hydraulic motor in the rear.
A little wordy, but your I/O is an engine.
Missxena
Is this a trick question? ;)
Well, when I go to the dealer for parts they never
ask "what outboard engine do you have".
Frank Acampora
A lot of the "Good ol' Boys use the terms interchangeably. Like at the tractor pulls, you will hear the announcer say "He has four Chev Ro Let motors running alcohol in that thing" I guess it's regional. Like here in Philly, they say "I tug it up" instead of the gramatically correct I tagged it. Well, "Chevrolay" makes engines.
BUT: If someone is talking about a car motor or engine we all understand that he is talking about that thing under the hood that makes it go. Same thing with boats--its the thing that makes it go. I don't correct him. It's no biggie.
Scaaty
Yep...(did I agree?.....yep again..if ya didn't get it..)
Ezrider_92356
iv always said burns fuel= engine / electric=motor
JB
Unless you are taking a fizix exam it is like tomahtoe or tomayto.
Barnacle_Bill
Like others here I was taught motors were like electric and engines were others. And I know they words are used interchangeably. But the english language has changed so much that sometimes I don't know what people are saying. Is that "bad" ? Or what? Bad meaning good nowaday. I think. You get my drift.
Drowned Rat
According to Websters, and although each term has other meanings especially engine, the verbiage is basically this for both; "a machine for converting any of various forms of energy into mechanical force". It would appear the terms are completely interchangable by their definition.
Ayuh,........
While I've been wrenching on Engines for over 40 years,......
My Love is tinkering on boat Motors.....................;)
Don S
Anybody wanna see a picture of my outboard engine? :D
As long as everyone understands what you are talking about, who cares!!!
Jerico
The way I was taught 30-something years ago, engines can run on their own. motors require a power source...
QC
I have a motor on my engine.
puddle jumper
I know what your saying but just to throw a kink in you thought petroleum is a power source "energy" and with out it a engine cant run.
My take on this age old debate is a motor is a generic name for a device that takes energy and turns it into mechanical movement. A engine is a term used to classify a particular type of motor.
just my two cents
