Who knows 5.7 Performance stuff? Cam Choice...
NHGuy
Hi, My boat is fairly light for it's power and I want to try to get all the oomph I can out of it. I don't have to, I just want to!
The engine is a 1988 5.7 serial # with the 64cc combustion chambers. 2 years ago I tested the compression and got 170 to 185. So at that point it was still tight. I did a timing chain to it last spring when I had the covers off to get rid of some oil leaks. I never did write down the cam code when I had it exposed. Too bad, that's a chance I wish I could get back.
I've been doing some reading about improving these engines in hot rod and hot boat sources.
I have gone onto Comp Cams forum and gotten some input. I am sure they want to sell their stuff, but I get that and I'm OK with it. I asked their help line for an opinion and they dialed me back to this cam, I was thinking too aggressive, too wild. That kind of thing is OK with me, I'd rather not go too far and regret the choice.
Since I haven't done this before I am thinking it best to stick with them as one source so their parts can be expected to work together as a system. I have found other cams with good improvements, but what I like best about the Comp one is that it's from a big reputable company and it's specifically for sterndrive engines. My type engine has been around for a long time, I bet COMP has gone through the learning about what can be done. To me that's valuable in avoiding reversion. I really do like engine noise, but if I don't have to keep my exhaust open to keep it dry I can go out early mornings without ruining my neighbors coffee or sleep time!
The kit I am looking at has Comp's 12-236-3 cam at it's center. It has what I need included as a package that's very complete. It has the cam, lifters, springs, retainers and keepers. I did a little research about running at higher rpm and regular lifters are supposed to be fine for the 5000 or 5200 rpms these cams turn. There are better anti pump lifters, lighter retainers, and roller rockers available but they are a lot more money. To me they are for folks with deeper pockets or more determination who want to run at way high rpms. I'll keep my eye on Craigslist for some rockers, they come around every so often. But I don't want to do that til I get screw in rocker studs.
Most days I just tool around at 1900 or 2300 rpm. That engine speed keeps me on plane and seems to be a sweet spot in my engine's powerband. It feels like it's turning as slowly as it can while sliding along easily. And it will do that with a pretty small amount of throttle once it's up on plane. If there's a bit of flat water I will run up to speed briefly. I don't hold it wide open for long periods, that feels too expensive. I run on a lake with a speed limit, so really high speed is not allowed. Although I have seen some streaks across the bay that look to be way over what my boat does! If I want to go fast I need to get away to another lake, which I sometimes do.
Here's a link to the cam page12-236-3 - Xtreme Marine
I also confess that I like the mild lope at idle of an aftermarket cam, I hope it has a little gurgle to it.
Silvertip
Re: Who knows 5.7 Performance stuff? Cam Choice...
Ahhhh -- have you thought about "why" I/O engine manufacturers don't do what you are asking about as an option? That engine will respond to any performance tricks you can do with a car. However, what a car doesn't have to deal with is a little issue called "reversion" and that doesn't mean backing into a parking space. It does however have to do with sucking water back up into the engine through the water cooled exhaust manifolds. High overlap, high lift cams that provide the rumpity rump you are looking for would do that and you would quickly turn a very nice 5.7 into a 550# anchor. The cam currently in your engine is the marine equivalent of a truck engine cam. Low end grunt is what is needed in a boat. High performance cams tend to move the HP and torque peaks up the rpm band. Since you indicate you are on a speed restricted lake and rarely run wide open, what's your point other than running more fuel through the engine that you also have an issue with. Even though the "description" for the cam you are looking at says it's the largest for I/O use, they do not have a clue what exhaust system your boat has and I seriously doubt they have extensively tested that cam with every system on the planet. I would also suspect they "push the envelope" so to speak regarding the reversion issue. My suggestion is to leave what you have as-is and save the money for fuel and other goodies.
Walt T
That cam is okay for wet exhaust. It will have ZERO lope. I had Crane grind me one with .500 - 521 lift and duration in the 290's. Its for a stroker motor though and it uses that cam pretty good. Silvertip is right though, its pointless to change just a cam in a marine engine. Any difference is most likely not going to be noticeable. But I don't know what boat you're running. A small bowrider, ok maybe you'll feel a little difference. A flat bottom hull with a jet drive that can go up to 6-7000 rpm well a cam may get you up there but the rest of the motor isn't made for that.
If you want higher top speed you need an engine capable of spinning a higher pitch prop and still deliver low end grunt with that same prop. That will take 50-100 lb ft more torque at 1500 rpm and 75-100 hp at 5000. A cam isn't gonna get you there. You do seem to understand it all has to work together so introducing more available airflow into and engine that already has what it needs will drop low end torque noticeably and the extra available air won't be used until the engine approaches 5500-6000 rpm. By the way look at the rpm range for that cam you posted, its for a higher revving engine and your engine is limited by the props on it. Comp isn't helping you.
So, if you decide to do it anyway, stay with your 1.5 rockers. You can hit the pistons if you change rockers without knowing exactly what you're doing. This type of valve train building requires patience, knowledge, and a degree wheel. No point in changing springs, that's for high rpms and you wont be getting there. If you want higher rpms, change prop to a lower pitch. Then go online and find your next motor. Seriously though, you have to build from the bottom up if you want enough torque and hp and give you reliable performance. You don't say what your current WOT rpm is now but if its 4800 it's still gonna be 4800 even if you do all that. I bet you're gonna try it anyway so keep in mind getting any kind of warranty or return on a cam or getting them to replace a damaged engine isn't possible. Use new lifters, the stock pushrods, springs and stock rockers are fine at this point. If you do change the entire train I really suggest pulling the heads for valve seats and complete valve jobs. You cannot expect your 1988 heads with however many hours on them to take the extra pounding the new train will give them.
Comp and Crane will tell you what you want to hear, we will tell you our experience. Hot Boat is a great source of information, but read everything. read the sterndrive letters and answers. They don't ever say to just change a cam on a stock motor.
NHGuy
Yuh I sorta had all those thoughts. My boat is small and light so liftoffs are easy even with a tall prop (23"). So if I send the torque north to get some horses I'm good with it.
Tell me why you think a bigger cam won't add some rpms. I'd expect a couple of hundred.
I might go down in pitch to a 21 to let the motor spin too. My brother has a 21 I can use for testing. That would be a good exercise.
BTW folks running more modern heads are getting great numbers, and many are just a cam and heads away from stock. Most of them are noise makers though, and I'm not too interested in being the annoying guy at the docks. Bench racing is like liars poker, you can never tell who's full of it unless someone is so off the reservation that it's obvious.
I think I will do this modification, I have an understanding of reversion and can deal with it. I will do an exhaust inspection after I run the motor to see if there's any water in there, sure hope there's none! I know how to get the riser empty before I do that so I can be sure to check it correctly. If I break something I won't be happy but I also understand that if it happens it's my fault and it's part of the learning curve for me.
They have another small block cam with more lift and the same duration at .050, that folks have run for years in twin engine go fast boats.
I'll come on here and confess if I botch it up, promise.
Thanks for the oversight, really.
Walt T
Sorry I haven't been on for a few days. Job sometimes requires 48-72 hours straight sometimes and we have a wannabe paramedic in school and some guys out for various reasons. Now with the cold and snow, for some reason every bonehead and his brother has forgotten how to drive in it. Been spending time with a reunion of sorts with my unit.
I'll explain why it's pointless to change a cam only, and about changing heads with cams which by the way can actually get you enough.
Walt T
Okay, the stock Chevy 5.7 for the most part already is capable of drawing more CFM than you need. Simple math says a 5.7 at 5000 rpm is roughly 470 cfm. Most 4 bbl carburetors supply 625. Granted, the stock intake and head design along with the exhaust isn't the most efficient. The cam shaft geometry is for a smooth idle with a good solid torque curve starting at low rpm and peaking around 4800 which is where the HP and torque curve intersect. Keep in mind for most stock engines the HP curve has already started to fall at this speed and torque is flat. For our purposes this is, for the most part, perfect. So the propeller pitch and blade surface (diameter, number of blades) is adapted to this specific curve to allow the engine to reach that intersection but no further. To allow it to go further will cause a noticeable drop off in power as the stock engine simply begins to run out of CFM. It runs out not necessarily because of the carburetor limit but because of the cam, valve, and air runner designs. This is not a bad thing. These engines are not intended to go beyond 5000 rpm, and are not designed to sustain that rpm for an extended length of time. The stock small block Chevy will actually starve itself for oil eventually because the oil drain holes in the pushrod valley cant drain oil fast enough back into the oil pan. For those of use who like bursts of high rpms and for nearly all automotive use that is a non issue. The stock Chevy small block is balanced perfectly to produce maximum power and longevity.
However there's always folks who want more and hey, why not? The small block Chevy is renowned for high performance applications.
To get more "launch and pull" we need more low end torque. To get higher top speed, we need to turn a higher pitch prop at 5000 rpm. I am going to stick with 5000 rpm because that is what our drives are designed to withstand. So, we want to be able to use a higher pitch prop as our standard prop. For most 18-20 foot bowriders this may not be too difficult as those hulls generally aren't too deep and require less power to push through the water than say a 22 foot cuddy cabin with a deep V hull. A skiboat is not a good choice for a speed hull as they are designed to produce a certain wake at certain speeds and easily become unstable. The flatter the hull, the easier it becomes to make it go faster at top end.
Okay I've covered the basic starting points. Prop pitch and hull type. I'm not going into prop types as I can type all week on that. For all of us folks who just want a little more, most of you will stay with the prop you have and try to turn it faster. Do so at your own risk. I do not and never will recommend exceeding 5000 rpm with a stock bottom end and a stock drive, especially when they have god knows how many hours on them.
Okay, lets start with camshafts. The very basic tenets are: Lift gets you low end torque, duration gets you high rpm HP. If you change Lift only then low end torque theoretically improves. This is the basis of "RV" cams and supposedly "marine" cams. This is the reasoning: High lift allows more air/fuel mix into the cylinder all other things being equal. lets assume the duration has not increased. What now happens is more air and fuel is now allowed to work on the piston in the same amount of time as the original stock design. More air and fuel = more force driving down the piston in the same amount of time. This is effective to a point. At higher RPMs the time allowed for the air fuel mix to travel into, burn, and then exhaust becomes too short and inefficient resulting in a noticeable drop off in power at rpms above 4000. This is actually fine with most RVs and trucks used for towing. To keep power climbing above that and to smooth out the curve requires duration. Duration is the amount of time or "degrees" a valve is allowed to stay open. There are many other factors such as "ramp speed" and length of time at max lift, but I'll keep it simple. At higher RPM the engine starts needing help moving the intake and exhaust gasses in and out. The camshaft achieves this by keeping both the exhaust and intake valves open a certain length of time to assist in the pushing out of exhaust gasses and pulling in a fresh intake gasses. This is called cam overlap. All camshafts have it. Its a good thing as it cools cylinders and without it engines would self destruct. SO... at higher RPMs we need a good match up of duration, overlap, and lift to feed the engine efficiently. Therefore if you buy a camshaft with higher lift and a small increase in duration it almost cancels out the benefit at low rpm because the added duration does away with the higher lift benefit at low rpm which is where a marine engine needs it the most. Lets go back to what I wrote earlier about high lift only, add valves staying open longer... and that shortens the time the mixture is allowed to burn in the cylinder. This is why high duration cams in high performance engines produce the "lope" at idle and why those engine produce virtually no power below 3-4000 rpms. The point made here is.. Add lift.. add torque. Add duration, less torque but higher rpm power. Look at RPM ranges on cam spec sheets, I can guarantee in EVERY application the "range" will always be higher rpms than your current stock engine. If your current stock engine is designed for a range 1100 rpm to 4800 rpm and you change that with a camshaft with a range of 1300 rpm to 5500, all you have done is move low end power to the other end. That's all. If you can spin that prop a little faster, well then you've accomplished a little more high end speed at the cost of low end grunt. If that's what you want, Yay for you.
Remember, a boat sliding through water has a massive amount of friction to overcome, and a massive amount of weight to push aside. It's like climbing a 6 degree hill with a trailer on the back of your truck in a 30 mph headwind. Therefore a very small increase in top end HP does you no good because it requires so much more to overcome the external variables. This is why you cannot use automotive logic for small power increases that would be noticeable on an automobile rolling down the road. An extra 30 hp that has been gained at the cost of low end grunt is negligible and may result in unsatisfactory performance in a marine engine.
So how do we improve performance across the board and be able to still have a good smooth running engine for dockside maneuvering? The quickest most efficient way to achieve this is to increase compression, and increase the amount of time the mixture is allowed to work on the pistons. A camshaft change, valve changes, and smoother runners help achieve this but as you see, it's very very difficult to get a solid performer throughout the range with just valve timing and geometry. You can add a supercharger or a turbo and that will dramatically increase available power. These top end changes will affect bottom end life as most folks know.
So, how to increase compression without removing the engine? Find heads with a smaller CC chamber. Most stock truck head valve chambers otherwise called "Quench chamber" are about 72CCs. There are non vortec heads with 64 CC chambers and a few older versions at 54 CCs. Do not under any circumstance just swap to a smaller chamber without know exactly what your valve to piston clearance is. Most stock 350's nowadays have reliefs in the pistons and a lot have dish pistons with a lot of area concave in them. This is to assist in the swirling of the mixture to achieve more thorough mixing at the molecular level so we don't have larger drops simply falling out of the mixture and not burning and simply getting pushed out the exhaust which is what is known as HC on your car's emission reports by those pesky emission tests. The dished pistons along with the head chamber design is all engineered to work together to give you a good solid burn with the gasolines available. It works very well. If you change it with a cam or head change, you change that burn quality for better or, more likely, for worse. THIS is why you will always hear experienced engine builders tell you "It all has to work together"
Changing a 72 cc head to a 64 cc head will increase compression. Usually by .3-.5 points. You may or may not need to increase fuel octane depending on what you are starting with compression wise. Most small block Chevy's start around 8.5 - 9.5. Above 9.5 usually requires higher octane due to the increased temperature of the combustion taking place. Anyone that's ever pumped up a bike tire with a bike pump knows the pump gets hot compressing the air. This is what higher octane gas does, it "resists" igniting at higher temperatures by the heat of compression only. This is also why it is useless to burn high octane gas in an engine that doesn't need it. Back to heads. Lets say you stick with your original heads, you don't pull them and just change "rockers" to a different ratio. The stock ratio is 1.5. This means: The rocker is like a lever. Movement on one end via the pushrod is transferred to the valve at a specific ratio so the spring can be compressed easier with less wear on the camshaft train. Changing that to a 1.6 ratio will push the valve open substantially depending on the camshaft lift. If you increase camshaft lift and also rockers to 1.6 you must have reliefs in the pistons to accommodate the extra valve travel. DO NOT change rocker ratios without knowing for a fact what piston to valve clearance is and how long those valves will stay open. This is accomplished by removing the heads over and over to measure that clearance for each piston. It is the ONLY safe way to do this. Rotating the engine on a stand and making sure nothing hits is useless. At 5000 rpms everything moves much differently and impacts can happen. That is why there is a specification for valve to piston clearance. I personally use flat top pistons and right now am running 72cc heads. I have a set of Vortec 64cc heads I will install over the winter and I will have to change the camshaft. That's only logical as I am completely changing the way that engine will be moving air through it. So, the point here is changing a cam and deciding to change the rocker ratio without fully building for this can cause serious damage and at the very least, poor performance. Here the "It all has to work together" mantra is absolutely critical. DO NOT assume a voice from a camshaft manufacturing company knows what type of pistons or heads you are currently running. I have seen it many many times. Valves ever so lightly touching pistons wearing a slight groove in them, which produces a ridge, which exposes a sharp line which concentrates heat on those sharp lines and eventually melts a hole in the piston.
Changing springs is strictly for high rpm. This helps stop valve float at high rpm. Valve float means the valves no longer actually close at high speed because the spring cannot react quickly enough. Using high performance hi load springs on a marine engine is a waste of money and can actually damage your valves and heads. The valve seats and valves themselves, along with rotators under the springs must all be engineered correctly or head life will be much shorter and sometimes there can be instantaneous damage if there is already a very tiny crack in a valve seat which doesn't really affect normal operation but will split wide open with the added pressures. If you disregard all the other stuff I have written here, listen to me now. Don't mess with the stock Chevrolet valve configuration without an expert. This requires a machinist to engineer your heads and valves to do what you want them to do. Leave it alone, and it will work for you, even with most camshaft changes. A good machinist who knows what cam you are using along with the bottom end you are using can be invaluable. Grinding off head surface should only be done with all this information known to the machinist.
You can determine what head type you have, valve sizes, and chamber CCs by looking up the casting number on top of the head under the valve cover. Sometimes the bolt configuration on the end of the head will tell you also but the number is best. Get it, look it up online, and know what you have as a starting point.
Chevy cylinder head Identification - Small block casting numbers
I'm getting long winded here, but I should cover carburetor size increases. Do the math, Cylinder Bore X stroke X rpm will give you CFM required. If you install a 1000 CFM Holley double pumper on a stock engine, you kill bottom end torque because the primary butterflys are much bigger than stock and when they open engine vacuum drops more than it does with stock size and therefore the airflow slows WAY down, the gasoline liquefies and drops out of the air, and the engine literally starves and requires more time to increase RPM simply because there is suddenly way more air available than it needs. That slowdown is the "Bog" you feel and hear when a 4 barrel carb opens secondaries suddenly. Mechanical secondary carburetors are known for this. Rochester Quadrajets are mechanical secondaries. They require a restrictor flap to keep that bog to a minimum. Most stock Holley 4 bbls are vacuum secondaries. Most times the don't open and when they do, it's very little. This is because the engine doesnt require any more. Even at 5000 rpm it is possible your vacuum secondaries don't open simply because the engine is already being fed what it requires. Don't believe it? Stick a bolt in the secondary linkage and force it wide open at full throttle. I guarantee you there will be zero increase in speed. You can't feed it more than it can take. Funny thing that. Here you have a 625 CFM carb on a 350. Do the math and holy cow it should use 460 CFM! Well grab a 700 or 725 and lets get this puppy going! And nothing happens but you notice your low end grunt has diminished. Math doesn't always mean that's what it's going to use. It's just a baseline. 625 CFM Holley vacuum secondary 4bbls are widely regarded as the best choice for stock Chevy 350 engine use. Don't change it without a corresponding correct modification so the engine will actually use it. The more available air, the faster the engine has to rev to use it, and if the engine is limited by prop pitch you gain nothing. The engine simply cant reach out and use the extra CFM if it is unable to achieve the required RPM.
Use caution, and get all the information you can. Understand the basics before you change the inner workings of an engine. For the most part, changing cams and even heads on a boat usually isn't worth the expense especially if you have to pay someone to do it. If you want true performance, pull the engine and build it for what you want from the ground up.
IT ALL HAS TO WORK TOGETHER
Feel free to send any questions to Walt@boatdoctor.com
My background in marine performance is dragboat racing. Pit crew for "Flat Hammered" blown gas flat drag boat, and 35 years building performance engines. I rarely build engines for sale anymore, usually just for friends and for free. Their parts of course.
There is a truly good feeling of satisfaction when its done right and you get out on the water at full throttle.
Walt,
a few clarifications
HP = Torque X RPM / 5252. it is at 5252 RPM the curves intersect.
The CFM for a 4 stroke engine is Engine Displacement (Bore x Stroke x # cylinders / by 2) multiplied by RPM and divided by 3456 (conversion factor) and then multiplied by the motors volumetric efficiency.
so for a naturally aspirated 350 running 5000 RPM with a volumetric efficiency of about 0.8 we get 405CFM carb needed. if the motor has a VE of 1.0, then we only need 506CFM carb The best naturally aspirated engine that I know of has a VE of 1.2. now adding a power adder such as a supercharger or blower, then the VE can be as high as 2.0 or 3.0.
The OP's engine has flat top pistons with 4 very minor divots in each piston. (I have been in more than a few). His motor has 9.4:1 compression, and he has 76cc combustion chambers on his 1988 vintage motor unless someone has swapped the heads. 64cc heads are available, however at that point, I would jump to vortec heads with 64cc heads. his stock longblock with 64cc heads will net you about 10.4:1 compression with stock gaskets
His stock cam is as follows for the 1988 vintage mercruiser 350
202? duration intake
214? duration exhaust
395" lift intake
404" lift exhaust
112? lobe separation.
as you can see, there is plenty of room for improvement on both lift and duration.
The cam that the OP is interested in
Operating Range: 1300-5500 RPM
Duration Advertised: 262? Intake / 268? Exhaust
Duration @ .050'' Lift: 218? Intake / 224? Exhaust
Valve Lift w/1.5 Rockers: .462'' Intake / .477'' Exhaust
Lobe Separation Angle: 112?
As I have stated, this is the cam I am running on my 1988 350 with vortec heads and the stock 625CFM holley (rejetted of course). Im happy with the mods I have made to the stock longblock, however I do plan on building either a 383 or a 406 soon.
Walt T
I already have been asked two very good questions.
1: "If I replace my 2bbl carb with a 4bbl the boat should go faster, right"
A: Perhaps. Any difference will be felt at top speed assuming the engine can actually use it. If you go to a 4bbl that has larger primaries it is possible you will lose some low end grunt, but possibly increase mid-range throttle response. Some folks like that. Here again, larger butterflys equal a lower vacuum signal. A lower vacuum signal means air is slowing down inside the manifold and fuel can liquefy and drop onto the surfaces. Once the engine speed "catches up" then performance is back. Smaller primaries and big 'ol secondaries are a hallmark of Quadrajets and why they seem to have better performance than others. People love the low end and mid range driveability. Quads tend to have problems at higher rpms especially when throttle is slammed wide open at mid throttle.
A 400 cfm 2 bbl is pretty good. Remember the 350 engine only theoretically needs 560-570 cfm at 5000 rpms. Dropping a 750 on it is useless unless you are gonna run 6000+ rpms. Personally though, I would install a 4 bbl 625 cfm vacuum secondaries with a nice shiny manifold for looks. That way I still have small enough primaries for good low end driveability and throttle response and more then enough carburetor to supply the engine without overdoing it.
2: "How do racing engines develop so much horsepower? I saw on Nascar they put out 1200-2000 horsepower"
A: Simple; R.P.M. Nascar engines are idling at 5000 rpm. (i'm exaggerating, but you get the idea) Their power is produced way up there. They go an entire 500 mile race at 7-10000 rpms. However those engines are worn out and must be overhauled after that. Top fuel dragsters produce 1500 hp at 12000 rpm and can accelerate to 300+ mph :O !! in 4 seconds. Then the engine needs major work in between races and the driver sometimes has to change shorts. Those dragsters "dump the clutch" at 7000+ rpm. Dragboats have small two bladed props specifically designed to "hook up" at high rpm allowing the engine rpms to reach the target "dump the clutch" speed. It is quite a sensation feeling those G forces on the water.
Tail_Gunner
Well if you have a older 260 hp 5.7 do a simple small block tuneup will make a world of difference.
1. Vortec heads
2. Blue ls-6 spring....for increased lift without head machineing.
3. Apr bolts's ...replace's the pinned stud's...increased lift and spring pressure good insurance.
4. Comp Cam's XM 270 hr @112 lsa...this a roller cam and you will need the whole chain
5.Comp cams 787 retainers.....Comp cams 648 keepers....Again part of the lift without machineing
6. Eldobrok intake
7.600 frm carb
Here are a few link's that will help you understand.
Valve Spring Upgrade - Beehive Valvesprings for the Vortec V8 - Car Craft Magazine
http://www.pacificp.com/forum/viewt...&start=0&sid=72a2f10f8cac040856d21288c9eebedd
If this intrest's you i will go into more detail..good luck.
http://forums.iboats.com/non-repair...cruiser-4-3l-need-advice-please-587005-2.html
A 4.3 build up same a 5.7...
Walt T
Scott, you are correct on the CFMs, I should have verified my numbers. The point is basically the same. Most guys don't realize the engines really don't need big carburetors.
I like going to Vortec heads and you did the math so you know what your compression will be as a baseline. I would suggest a block drilled for roller cam as the best Vortec cams are rollers. Hydraulic is fine though. Your 1988 block should have the rollers. I would look at 450 lift max and not go above that without some head work. His lift numbers are fine though. Vortecs really aren't high rpm heads which makes them so good for marine use. Duration at 260s is more than enough, in fact I'd try a smaller duration in the 230 range. Keep in mind some Vortec heads have to be modified to take the standard pushrods he currently has and some are designed with different types of rockers. A good machinist can fix em up. There are so many cool things that can be changed with Vortec heads. For example, for my engine I used flattop pistons which really doesn't give a good "quench" effect but with Vortec that can be changed with different thickness head gaskets. Obviously any differences are subtle and probably wont make much difference in a boat.
The stroker is a whole different animal and a very fun build. Buy the kits that have the specific stroker rod cap bolts for block and cam clearance mostly for peace of mind. I used a custom grind Crane cam if you're interested in the specs, I'll find the cam card. The Vortec mods obviously will require a different cam as will your stroker. If you don't mind adding a bottle of 104 to your gas I would run 10.5 compression. You will not regret it. It's expensive, sure, but how much gas do we truly burn in a season? Not that much actually in my case. Cruising Lake Powell is one thing, day trips aren't really that noticeable on the pocketbook. Like I said, there's nothing like that feeling you get slamming the throttle down and feeling the boat literally jump forward and pull hard all the way up to top speed.
Lunati cams will custom grind for you which gets you power where you want it. I have actually built wet exhaust marine engines with wild cams that required a diverter valve at lower rpms to prevent inversion. The valve actually stopped water flow to the exhaust. The guy wanted a quiet sleeper and wouldn't go to through hull. That was a really cool build. Didn't have anything until 3000 rpms though.
QC
It is because of the constant "5252" as you note, but it is meaningless. When you use Newton Meters to kW they intersect at 9549. So if you use metric numbers you should build to 9500+ RPM? They are an "accident" of the math. Torque and power intersection are only lines on a graph. They are different things so their intersection means nothing. Just a little clarity on that one as I see people think it means something to determine an engine build. It doesn't. Think about this way, let's say you have a 1750 lb/ft 13 liter truck engine, that has it's peak of 500 bhp at 1800 RPM. The lines never intersect but I guarantee it will get a lot of work done ;)
Walt, most automotive blocks may have been starting to turn to roller cams, however the marine market was a transition period in '88 and '89. I can guarantee that my block with a manufacture date of 1988 is indeed a flat tappet block.
QC, you are correct. I should have stated that HP = Torque in lb-ft x RPM However since HP is purely imperial and not metric, that could almost be implied. you are right about the 13 liter truck not getting to 5252 RPM (where the HP and lb-ft curves would intersect, however I have seen a 19 liter perforate the block at 4500RPM due to a faulty governor. our Marine 8.3 liter would spin 3600 RPM without problems all day long.
QC
Yeah, my point was only the arbitrary nature of the crossover point and some see it as indicative of something. That's all. Saw it in a Motorcycle mag recently and I wanted to throw it out the window, so I was revved up already :eek:
Walt T
You guys are right, lines on a graph are just that. I did make the point that it is just a baseline. Every engine is different, almost like fingerprints. You can build two exactly the same and they'll perform different and you'll have to tweak them differently.
I used 5000 as my number, as I stated in my essay that's what I was using as my limit. But you are right, 5252 is the standard.
To Jeff C; Sorry your e mail bounced back as undeliverable. My total cost for a 383 stroker was 2486.00, 3027.00 with manifolds and risers.
That included: Block align bored, cam bore align bore and cam bearings installed. (I asked for them to check the crank and cam bore alignments I can't tell if they actually bored them or not on the invoice.)
Bore to .040 over, deck surfacing, complete heads refurbish, new valves and 3 angle grind. Nothing fancy. Bone stock 72cc truck heads. Hot tank and all that good cleaning stuff.
Stroker kit, included crankshaft, pistons, rings, rods with stroker specific bolts, main and rod bearings, externally balanced flexplate which we don't need. You can get the right harmonic balancer also depending on if you need an internal or external balance. Camshaft and rollers from Crane cam.
I also was admonished by Bill at Performance Machine in Wheat Ridge, CO to keep it CLEAN. I'm pretty sure he didn't charge for the admonishment.
I bought a '89 truck 350 engine from a guy on craigslist. I stripped it and took the block and heads to the machine shop and was told the block was cracked in the valley which is common when overheated. The crack actually isn't a big deal. Bill did try to drill a stop hole but the crack simply got longer. So that was 250 bucks down the drain and I didn't include that in the total price. You pays your money and you takes your chances. I wanted a new block because my original '88 block was not a roller cam block. I bought another complete engine from a girlfriend who had conveniently had her Camaro hit while parked in front of her house. Every engine including the original engine out of the boat were all 2 bolt mains.
The machine shops always check for cracks and damage before they start any machining, so I didn't have to pay for two blocks being machined.
2 bolt mains are fine for nearly every build. So are 4 bolt mains. If you want 4 bolt mains by all means buy that. You can also have a 2 bolt main block turned into a 4 bolt main block by any machine shop. For my particular purposes it's not necessary so I spend money where it's needed. Some guys will say you must have 4 bolt mains and some guys swear all marine engines are 4 bolt mains. Nah.
I did all strip down and engine assembly myself, but paid Best Marine in Denver to pull and re install the motor. (350.00) All the transom O rings, U joints and bellows, and a shift cable were not included in the above price.
You can buy complete stroker motor long blocks completely assembled starting at around 3K. Craigslist and E bay have a lot of less pricey motors, just know what the warranty is.
I don't build and ship engines. I simply cannot warranty engines installed 2000 miles away where I have no control the quality of the install. I'm just some guy that likes to build motors.
