Who makes a good Boat Motor Support ?
roscoe
Re: Who makes a good Boat Motor Support ?
Swivel-eze Cabelas and Bass Pro shops make the best.
Several models and styles available.
Shop around.
marquette
the first 2 motor supports i had both had pins with spring clips to hold them on the trailer. a pain in the a** to get under and hook when the baot was dripping water on you and the launch was muddy. the one i have now has a plate mounted on the trailer that the support bayonets into with a quarter turn. it can get installed while standing high and dry behind the boat. a major improvement. other than that all three worked the same and seemed to be about the same quality.
oregonboatnewb
Does the one witch the pokey end just go in that hole then to the bullet to hold motor up, and the other one with the fork end, go somehow onto the trailer ?
http://www.opentip.com/Sporting-Goods/Swivleze-Spb-Bolton-Transom-Saver-Spb-p-669049.html
This is how my boat looks
