its leaking water and lube mix is it suppose to and what is that little pin whole?
N nocomplnts83 Cadet Joined Jul 30, 2009 Messages 10 Aug 2, 2009 #1 its leaking water and lube mix is it suppose to and what is that little pin whole?
J john from md Commander Joined Apr 13, 2008 Messages 2,184 Aug 2, 2009 #2 Re: whole by lower unit bolt? There are about four to six of these drain holes. They drain the leg in the area around the water pump. You should keep them clear so water doesn't lay in that area. Just clean them out with a nail or drill bit. John
