I know you are supposed to fill it from the bottom up, but without an adapter I can't do it right now.
Is it possible to fill from the resevoir and use gravity feed, remove the bottom screw until lube comes out then put it in and leave vent open until lube comes out of it?
Just did the pump - I hate questioning myself as to whether the vanes are going the right direction. Checked and checked and then when it is together start to question it UGH!
thanks,
Jeff
thanks,
Jeff
