Re: WHY DECARB IMPROVE CYLINDER PSI?
'Afternoon Carlos Eduardo,<br /><br />durring combustion, carbon residu results. After prolonged periods, Carbon deposits can build up on the different surfaces in the cobustion chamber including: piston domes, head, rings,....<br />After prolonged carbon build-up there is risk of HOT-Spots on the piston and head as well as possabiliity of of carbon build-up on Rings causing them to stick. <br /><br />Carbon build-up on head and pistons can cause detonation/pre-ignition which can result in serious engine damage.<br /><br />Build-up on the rings, resulting in stuck rings can easily cause loss of compression. As well, buid-up can get a ring caught-and SNAP! big probleem.<br /><br />Different motors, oils, environments, running conditions,.... influence the buildup of carbon.<br /><br />From what I understand, it can't hurt the motor to de-carb, even if it doesn't need it. <br /><br />On the other hand, if it is suffering from carbon build-up and you take care of it,.....<br /><br />I think that the general concensus is, "better to be safe then sorry". One rule of thumb is to perform a decarb at least once per year.<br /><br />I'm sure others can offer more on the subject.<br /><br />Good Luck<br />HAVE FUN!
