redbull660
- Joined
- Jul 25, 2004
- 76
I have a 1994 yamaha outboard 2 stroke jet on my 94 hewes craft. Last year it quit running. It would run fine and then just shut off, It did this 3 times so I put it on the traler and did a compresion test and one cylinder was way down to only 10 pounds of compression. I have recently ordered a new powerhead threw Iboats, but am concerned on why this happened. I have been talking to a guy and he says that It should not be the oil pump because it runs off of a gear on the crank shaft. Before it quit it would run fine and then shut off like it ran out of gas. <br /><br />I did take the head off and found that there was a lot of corrosion inside of the water jackets. Do you think maybe it got to hot. Thanks, any info would be greatly appreciated.
