Re: Why do so many mount vhf antenna near helm?
Towdog, I may be mistaken, but I do believe the rule is to keep the antenna wire at least 3 feet long. The distance between the radio and antenna, as far as I know, doesn't really have much of a rule. My little boat's radio and antenna probably aren't 18 inches apart, but I have the full 16 feet of cable wrapped up and stored under my steering thingy, and my radio works great. I use it every time I go fish, and nobody ever has a problem hearing me.<br /><br />I certainly agree mount it as high as practical. To figure out the estimated range of your radio, use this formula:<br /><br />Square root of the height in feet above the water of your antenna x 1.42. <br /><br />If your antenna is 4 feet above the water....the square root of 4 is 2 so 2 x 1.42=2.84miles. As you can see, height is the key. If you put an antenna on top of your home, say 25 feet up, 5 x 1.42=7.10 miles. Add that to your 2.84 miles and you should be able to talk to your base station out to about 10 miles over water.<br /><br />I would only suggest the purchase of a rather expensive antenna tester by Shakespere. It shows SWR and transmit power. I found out my radio on high only puts out about 17watts, as opposed to the advertised 25. My father's Uniden MC210 puts out the full 25, in fact, its closer to 30.
