Re: Why does fuel come out of Carbs drip pan when i flood motor?
thisold...<br />While i amnot intimately familiar with your motor, MOST carb flodding issues are due to needle & seat issues. finding "over-flow" of fuel is NOT uncommon in cases where "flooding" is a problem, but it could become costly, should it catch fire. I'd suggest you get a manual for the carbs, some carb re-build kits, then go through them to throughly clean them, then replace needle & seat, all gaskets, etc. If you are unfamiliar with this sort of work, I'd suggest you eithe find a buddy who is to help, or leave it to those who are familiar with carb rebuilds, as especailly two stroke motors are pretty sensitive to having the specs set pretty close..<br /><br />Goo Luck, Obiwan...
