Re: Why does it do this??
Hi CPTom21. Glad you got her running better. Most folks here are NOT big fans of the aerosol style carb cleaner that you spray into the carob throat as the motor is running. It's fine to use it if you take the carb off in order to rebuild it, in which case the aerosol carb cleaner is great for blowing out the passages. However, you don't really want to use it on a running motor. Carb cleaner is an organic solvent designed to dissolve organic solids like carb good, dirt and the oil in your fuel!!!, which is vital for keeping all of the innards of the motor properly lubricated. The carb cleaner would actually dissolve this oil and cause it to be burned off without doing its job. As a result, your motor's internal components will be starved for oil, which is about the worst thing you can do for these old 2-strokes. I would recommend removing the carb and thoroughly cleaning it and replacing all of the consumable gaskets (i.e. "rebuild" ) the carb. It's a quick, cheap, easy and routine job to do. You can get a carb kit right here at iboars for about $20, or you can get one at NAPA auto parts store. If it's not in stock thye can have there by the next day for FREE. Again, the aerosol carb cleaner is fine for cleaning/blowing out the passages when you rebuild the carb, but not advised for use on a running motor. You may also want to decarb your motor. No, that doesn't mean removing your carb (LOL), it means you want to "decarbonize" the pistons. Over time black, carbon deposits can/do build up on the pistons and rings and can impede performance. By removing theses deposits the internals are allowed to move much more freely and smoothly. Sea Foam and/or Deep Creep is a great product available at any auto parts store for abut $10 a can. It comes in liquid or aerosol form, either of which is fine. It's great stuff and will work wonders for you motor, especially if it's been sitting a while. It is safe to spray Sea Foam into the carb as the motor is running. It will smoke like #@$#@$, but that's what you want. Those are all of the carbon deposits burning away. Spray 4-5, 4-5 second sprays into the carb as the motor is running at med-high idle. When you spray in the Sea Foam the motor will smoke and the rpms will drop. You may have to turn up the idle a bit to compensate, but that's normal. The rpms will come back up again when you stop spraying. After doing this 4-5 times, let the motor sit for 20-30 min, then start it up. Again, it will smoke like #$#@%#$%, but that's normal. Run the motor at med-high idle until the majority of the smoke burns away, then get the boat on the water ASAP and open up the motor up to WOT to bring the motor up to temp so it can burn off the remaining deposits. You'll be amazed at the difference it will make. Now that you know how all the knobs do and how to adjust them, I would suggest you do a carb rebuild and/or decarbonization (Sea Foam) treatment. The whole job will cost about $30 and take an afternoon. These links can get you started.
http://www.iboats.com/Carburetor-Ki...15.1964--**********.704433472--view_id.174131
http://www.duckworksmagazine.com/04/s/columns/max/25/index.cfm
http://forums.iboats.com/showthread.php?t=167352
http://www.youtube.com/watch?v=sLOuUWV4GrQ
http://www.youtube.com/watch?v=vPVqBrhRXUU
