Over30S130
- Joined
- Oct 25, 2010
- 21
I don't know if this in in the right section ,but here goes anyway. I have a 1979 Ranger 168V that I recently acquired. I was checking things out and noticed the the steering was stiff so I greased all points on motor with no luck. Still have to use two hands to turn wheel-don't think this is normal given the fact that it is on the trailer at the moment, but that 's another story as I have found some options on here already to address that problem. In the process of watching the steering rod work back and forth while pushing and pulling the motor, I noticed that there was another cable/rod just laying in the transom that operates in the same direction as the one connected to the engine. The previous owner had mentioned that a motor swap was done-it currently has 1990 Evinrude 120 V4 mounted right now. At first I thought that the extra cable might have been the original that might have been left in due to being frozen and the PO did not want to bother to remove it ,but then I quickly noticed that it was not frozen and moved. Could the transplanted motor have required a specific cable/shaft to account for there now being two cables and he just didn't want to bother to remove/snake/cut the old one out? If so, then why are they both hooked up to the steering wheel? At first I thought, maybe the motor takes two cables to turn such as in a push/pull type steering, but they both operated in the same direction and I did not see anywhere else on the motor to secure an additional cable for lack of a better term for say a 'dual assist steering', if there was such a thing. Anybody have any ideas as to why this is? As a side note, while working the steering, I did see some water come out of the motor end of the extra steering rod which may answer somewhat why my steering is difficult. I have not disconnected the one rod from the motor to help narrow it down to motor/cable/steering box, but have a pretty good idea it's not in the motor swivel. Boat has not been used in quite a while. Stumped on this one.
