Why does my o/b smoke in the tank?
1970kayhydro
Just wondering why my 71 johnson 40hp smokes pretty bad when I tank test it and none when I take it to the river? What causes this, is it normal?
see..
samo_ott
Re: Why does my o/b smoke in the tank?
That's normal. Use a fan to clear the smoke if need be.
1970kayhydro
the smoke isn't a problem where i live. just wondering why it does this.. i decarbed it and that was BAD smoke!! my closest neighbor is at least 500 feet away and they don't mind it every so often.
Sea18Horse
I think it has a lot to do with the fact that you can't really load it properly in the tank and get the exhaust temp up. that coupled with the more confined space makes the smoke more pronounced. Just out of curiosity are you running 50/1?
Cheers.............Todd
tashasdaddy
very normal in a barrel. also at idle, as most of the exhaust come out the relief ports, rather thru the prop.
1970kayhydro
Yeah its 50/1 and I have been using premium gas and the best o/b oil i can find at auto zone.
iwombat
Save your money on the premium gas - it doesn't need it.
1970kayhydro
yeah i kinda figured that, but i hardly use the boat. its only fun for a short time, you can't move around in it much. last time i took it out we drove around for about a hour and a half only tring to dry out. soon as i was slowing down to turn around there was a 17-19' taking off and we did fine over the first wave but the second landed in our laps. Then the gas got low and we still looked pretty silly back at the dock still real wet.
