Why does prop spin when in neutral?
RTripp
It doesn't spin fast and I can stop it with my foot. But, I did notice yesterday in a very calm spot the spin was enough to push the boat at a very slow crawl.
gear oil drag. prop exhaust will also push the boat
Joe Reeves
Deleted error... my mind was elsewhere apparently. Yes F_R, I'm aware of the lower unit setup... was out to lunch so to speak!
F_R
I know that Joe knows this, but in reality the pinion gear AND both directional gears are all spinning any time it is running. But the reverse gear is provided with better bearings (less drag) because it usually is spinning in the opposite direction of the prop shaft. Therefor the gear with the most bearing drag (forward) wins out in the equality test and the prop turns in that direction.
Please don't stick your foot in it any more.
The pinion turns both forward and reverse gears when the engine is running.-----On most motors the forward gear has a plain bushing on the propshaft.----The reverse has a needle bearing that often is NOT contacting the propshaft.----It is drag in the forward bushing that turns the propshaft.---On most motors the gears are not connected to the propshaft by splines .---It is the clutch dog that is splined to the propshaft.
Crosbyman
some of you less younger fellows may remember the old VW commercial/demo explaining modern "automatic transmissions" where the demo guy would use a large bowl on a lazy Suzan plate , an electric egg beater and olive oil....
without touching the bowl.... the egg beater would spin the oil in the bowl....and magic:confused: the bowl itself would start turning thanks to the friction... with the olive oil.
same with props I guess
