I have a 1977 Sea Ray, with a Mercury Mercruiser (GM) 6 Cyl. (Stern Drive) 165 HP
Motor S/N 4610110, I think the motor is also a 1977.
It has the regular fuel pump on the motor, but someone has installed an electric pump in the line between the gas tank and motor mounted pump.
Should this be there, pumping fuel to the other pump? Also the wire gets heated up after running a while on the electric pump. Should I take it off and just run the one pump, or check and see if it is bad being the reason the electric one is on it?
