Why is high speed needle affecting idle
BlackoutBill21
1962 7.5 Evinrude... after reving to high speed... stalls and dies... when it idles the low mixture is set at 1-1/2 out... but motor changes rpm depending on where high speed needle is...
if i lean up the high speed needle motor will not stall after reving however if I don’t re richen needle, motor lean sneezes and dies.
brand new tank bulb and line. Converted to fuel pump single line from double pressure tank.
F_R
No such thing as a 1962 7.5hp Evinrude. Tell us what you really have so we have a chance. Model #???
I believe all the fuel including the low speed mixture goes through the high speed jet.-----So yes there is some effect !-----Best to learn the proper procedure for adjustment.-----Or correct what is really wrong with the motor.
jimmbo
1958 or older, or 1980 - 83. I don't think the 80 - 83 engines had an adjustable Hi Speed
If it was a 7.5 converted from a pressure tank it is from the 1950's
Joe Reeves
The two adjustable N/V type carbs are to be set up as follows:
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason `to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
F_R
Make sure the round cork-like gasket is on the main nozzle in the center of the bowl.
BlackoutBill21
My fault on that. 1957. I have 6 projects going right now. When you guys do these Kits, do you put the plastic ring in front of the cork inserts?
kbait
I don’t, unless the carb had one originally. Those kits are usually made for many models/hp’s, and often contain ‘extra’ parts..
