It's just a 35hp force from the 80's. But it is incredibly difficult to pull start. I can pull it easily with the spark plugs removed. With the spark plugs in, I can still turn it over slowly even with just 1 hand.
Disconnecting the plug wires didn't make any difference.
Am I setting it up wrong? I put a rope through the notch on the top of the flywheel, wrapped it around a few times and try to pull. I almost jerked the boat and trailer around. The compression is 145, 145 in both cylinders. What could it be?
Backstory:
Outboard stiffened up pretty bad over winter. Worked flywheel loose by hand until it turned over easily with the plugs out.
Electric starter had been getting progressively weaker over the past year and after the winter it wouldn't turn the flywheel around fast enough to get it to start, it barely spins it around until it gets to a high compression point in the rotation and gets stopped.
Backstory:
