J70TLEIE 1991 johnson 70hp
Motor runs good and is reliable now, but idle is still rough. when i checked the timing the screw is all the way in. A boat shop told me thats probably because the motor is "worn out and wouldnt idle." Thats my problem if i set it at the 4degree Atdc it wont idle. Compression checks even at 90 pounds(is this enough and if not how should i raise it). Carbs have been cleaned several times. New champion plugs .030. New fuel lines. Flushed gas tank. No air in fuel line sight hose. Replaced coil 3 due to occasional lack of spark.
its a minimum of $325 dollars to have it checked out here which isnt happening so im pullin my hair out here!! Thanks in advance guys.
