Hello all, I have a 1966 Johnson 60hp v4. It did not have any prop on it when I got it. So after lots of frustrating searching I think I found what I needed...
Or so I thought.. I ordered a prop off ebay part # 379260 size 10x9/14. Got the item it is in brand new condition, part number and size is clearly stamped on the prop.
My problem is - Pin drive is correct. Size seems ok.. But the prop does not "mesh" with the lower unit. if that makes sence, there is no teeth on the shaft to mesh so to speak..
But the rear of the prop does not seem wide enough to go "onto" the lower unit. the lower unit has almost like a ridge that the prop is supposed to go around.
I have looked up the motor model number and it comes back as the correct motor, looked up the prop number and it comes back as the correct prop.
What am I missing here??
