hondarider188
- Joined
- Jun 15, 2011
- 160
on my 1985 Evinrude 140hp the lower unit or foot is full of water. i found this out when i hooked up the motor flusher to it and started the engine at first water was coming out with the exaust but there was no pee stream but after about a little under a minute it started coming out. so thats when i got wondering why it took a second to come out so when i got looking close there was water coming out of the seam where the lower section of the foot and the upper section meet. so what does the water travel through once its pumped up into the foot what i mean is does it travel up through a hose or is it just pumped into the entire foot. so then i checked the oil and it was almost a milky white so i is leaking water but where is it coming out at. is it getting in by the pump then just has a leak in there somewhere when its makeing its way up to the engine or is it sitting in the water and coming in through the same seam.
