Why no spring loaded seats on boats?
bowman316
You know how a tractor, or tractor trailer has a spring loaded seat, that bounces up and down as you go over bumps?
Why do they not make those for boats?
When i rough seas, that would be nice, as you are getting thrown around. I think that would help me keep my had steadier on the throttle.
dave11
Re: Why no spring loaded seats on boats?
Check out seaspension.com
They may be overkill for your boat
lowkee
That sounds like a sweet idea! I'd bet a spring and shock from the rear suspension of a motorcycle would be perfect for that use. Make the seat have a solid front mount and the rear attach to the shock. It would absorb in a rearward motion, but certainly better than breaking your spine on that random chop.
Makes you wonder how well a real tractor spring would hold up, since it is purpose built. We used to have a Case tractor with a steel seat on a curved metal 'post' which acted like a u-shaped spring. Never once regretted hitting a bump on that thing, even without any seat cushion at all.
ondarvr
They're fairly common here, and very nice in rough water.
bowman316
what about a whole deck sitting on springs, kinda like a suspension on a truck?
prob a crazy thought...
Bob_VT
A moving deck on a moving boat in the water???? You would walk like you were drunk ALL the time! I would let that idea go......:rolleyes:
tashasdaddy
many bass boat seats have springs.
Silvertip
You must not be paying attention because there are all sorts of spring and air suspended seats that are fully adjustable. Granted, these are primarily pedestal mounted but they are available.
high'n'dry
Most boats intended for rough water use have standing stations as per the majority of center consoles for saltwater use. Your legs are a great shock absorber. Some of the higher end cc boats have active/suspension decks. Shock absorbing mats are often used as well for standing on and are very effective and reducing shock at high speed over rough water.
JoLin
I'd rather stand. Sitting blocks my view of wave action and how the boat is responding. Also blocks my view of the fish and crab traps I have to avoid (sometime it's like running a slalom course out there).
Maybe it's just me, but I instinctively stand at the helm. I'm not comfortable sitting while underway.
Yepblaze
Like the old grange dance hall built on boxcar springs.
CaptainPointless
We used custom seats on triple-bolster Seaspension pedestals on the USCG rescue airboats we built (in fact, if you go on the website, you can see our airboats in the Military Portal). Believe me, if anyone's ridden in a jon boat before, you know how hard the boat feels when it slams its flat bottom down on a wave crest. Now multiply that by 10 -- that's how it felt in the airboats without the pedestals. With those Seaspension seats, when you hit a wave, it feels the same as hitting a SMALL pothole in your car. And Peter Burer, the owner of Seaspension, is a great guy, and will work with you on a viable choice for your application. In fact, I'm thinking about picking up a set when I finish my resto.
So in short, if you want a fast solution, I'm sure a lightly shock-mounted seat will do the job perfectly fine. If you're planning on pounding your boat or fishing in choppy seas, the Seaspension seats will provide a much more comfortable and enjoyable ride.
My .02
skargo
Banned
They are like a grand apiece :eek:
Me too, just seems more natural.
Here's a nice DIY option.
http://www.hookedoncatfish.com/seats.html
TexMojo
I have air ride seats on my sled and they are pretty necessary from time to time. I think most sleds out here have the air rides. Gotta remember the pitch on these things is not much so you brunt alot of chop if your in it. Their designed to run rivers not chop, but with the seats, I do occasionally hit the salt the they help.
roscoe
There are pedestals with springs, seats with springs, seats with air bladders.
It all depends how deep your pockets are.
Shizzy
Ensign
my friends bad arse Alumacraft fishing boat has them. sure makes shooting across the lake at 55MPH much more enjoyable.
Home Cookin'
I'd be surprised if springs/shocks last very long after use in rough salt water.
I almost always stand when drivnig, and usually drive. I have to consciously tell myself to sit down so I won't get worn out, and on my helm I can see OK sitting down in calm, daylight, familiar or open water. The few times I ride sitting down on a bench seat I understand my passengers' complaints! Of course, a boat cushion does wonders.
ReelPlumber
foot cush or sea deck pads help alot while standing. I installed autopilot last year and now I sit, find a comfortable speed, and relax a little. Takes the wear and tear off the body from standing all day.
