Re: Why not a gearbox
My idea would be direct drive in low, then overdrive for high i.e. planentary gears. A Lenco transmission would work great. It would handle the power and have low friction losses.<br /><br />The difference in ratios would be small, just enough to reduce the rpms to get better economy.<br /><br />Lets say you had a prop pitched for 40 mph top speed at 4500 rpms (Inboard motor config). You shift into high, you would reduce RPMs to 4000 and get about 38 MPH. Your hole shot would be much improved, and I imagine your WOT economy would be much better.<br /><br />You could use it as a cruise gear. When cruising 20 mph at 2500 rpm, you could put it in overdrive and get 20 mph at 2000 rpm. You would need a motor with a very broad torque curve. I am thinking twin 454 Chevy inboards.<br /><br />But funny thing is, if it were such a great idea, why isnt anyone doing it?<br /><br />Two possible reasons, 1) no market demand 2)it wont work.<br /><br />Ken
