Just got the Fusion ipod head unit, doing a little prep before the install, why would you want a switched and unswitched power source. The presets and clock will be maintained via Eprom. Seems unswitched would just set you up to run your battery down if you forget to turn off your stereo. In fact the previous owner had a switch installed in line with the battery to turn cut all power for that reason. TIA
