Re: Why the buddy bearing?
Bearing Buddies are a well proven concept.....but......they can be problematic if not fully understood. They can be over-greased causing the rear seal to leak or the Bearing Buddy to fall off. I have been a firm believer in BBs but lately I have tried a new concept, I use conventional dust caps, pack the bearings with food grade grease and pack the hub cavity and dust cap 25% full. I adjust the bearings on the loose side (about 1/32? at top of wheel) this prevents the hubs from getting warm. The food grade grease can tolerate water better than marine grade grease if any water was to get sucked in. The downside is food grade grease is expensive at $20 a tube. Even with the bearing buddies I have been using food grade grease for over 15 years on trailers and I/O zerks.
